1uzfe
Posted: Wed Apr 28, 2010 6:52 pm
by mightyhilux4x4
much searching has lead to confusion some good solid advice would be appreciated..
project RN46 hilux (s/c) 18r with 4 speed solid axle 4x4
want to : lexus 1uzfe v8 ( for fuel economy mainly)
!!! my question is what box to put behind it (really want an auto)
but what are the choices (money is an issue) but still need it to be reliable ..
your expert advice would be appreciated :?:
Re: 1uzfe
Posted: Wed Apr 28, 2010 6:55 pm
by Engineer
Fuel economy :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Re: 1uzfe
Posted: Wed Apr 28, 2010 7:26 pm
by mightyhilux4x4
better than say a 350 chev with a 600cfm carby
Re: 1uzfe
Posted: Wed Apr 28, 2010 7:31 pm
by Jerry
The A343f bolts up to it apparantly
Re: 1uzfe
Posted: Wed Apr 28, 2010 11:18 pm
by Engineer
Jerry wrote:The A343f bolts up to it apparantly
they do but you need to replace the input shaft and oil pump with the factory 1uzfe shaft n pump and then get your wiring sorted
Re: 1uzfe
Posted: Thu Apr 29, 2010 8:07 am
by Pedro
which is about 3 wires for a manual auto, driven from the gear select indicator switch on the side of the auto, but you want to use the switch of the lexus auto as the a343f has a couple of outputs missing,
Pedro
Re: 1uzfe
Posted: Thu Apr 29, 2010 9:36 am
by kbushnz
Nose chops are a good option.
Comes with eng, auto, computer, dash etc etc.
You can even turn the key and hear it run.
All you have to do is fit the Transfer case.
Might cost a bit more than just a motor but its all there.
Calvin
Re: 1uzfe
Posted: Thu Apr 29, 2010 10:41 pm
by mightyhilux4x4
has any1 tried keeping the lexus auto and addapting a transfer case from a surf (sounds easier on the electrics side)..
Re: 1uzfe
Posted: Fri Apr 30, 2010 9:06 am
by haydgq
mightyhilux4x4 wrote:has any1 tried keeping the lexus auto and addapting a transfer case from a surf (sounds easier on the electrics side)..
I've got a factory Lexus auto that I brought from Wayne at the cartune company in Hamilton, he fitted the surf transfer case on the back and we have wired it to run in manual mode.
I would reccommend ringing cartune and talking to Wayne or Kelvin (07-8479969) as they know all the little tricks and whats easier etc
And all i can say is get some one like Cartune to do any wiring if you are unsure as i had a farkwit :twisted: wire up my truck who had apprently wired a few 1uz's before but he made so many fuckup's that all the factory loom and ECU were pulled out and we fitted a link.
Re: 1uzfe
Posted: Fri Apr 30, 2010 8:16 pm
by T-Boon
If i ever get around to it, i`m gonna run a surf box, with adapter bellhousing, should be good azz.
Re: 1uzfe
Posted: Sun May 02, 2010 8:01 am
by mightyhilux4x4
are you meaning that the transfer case is wired to run manual or the auto its self..and is the lexus auto behind a 1uzfe
Re: 1uzfe
Posted: Sun May 02, 2010 9:35 am
by Big
Or get a LJ70 series box off a prado.. they bolt up also but only thing is the xfer is offset.. not right for the hilux.. Have a look at lextreme.com and a bloke has converted a ssurf xfer to lexus box and worked a treat.
cher
here is the link
http://lextreme.com/forums/showthread.php?t=2367
Re: 1uzfe
Posted: Sun May 02, 2010 7:53 pm
by haydgq
mightyhilux4x4 wrote:I've got a factory Lexus auto that I brought from Wayne at the cartune company in Hamilton, he fitted the surf transfer case on the back and we have wired it to run in manual mode.
Hey, the transfer is a surf electric jobbie and the lexus a341-e auto trans is wired to run in full manual mode and yip its behind the 1uz in my Hilux.
