1uzfe
mightyhilux4x4
1uzfe
Post by mightyhilux4x4 »
much searching has lead to confusion some good solid advice would be appreciated..
project RN46 hilux (s/c) 18r with 4 speed solid axle 4x4
want to : lexus 1uzfe v8 ( for fuel economy mainly)
!!! my question is what box to put behind it (really want an auto)
but what are the choices (money is an issue) but still need it to be reliable ..
your expert advice would be appreciated :?:
Engineer
Re: 1uzfe
Post by Engineer »
Fuel economy :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
mightyhilux4x4
Re: 1uzfe
better than say a 350 chev with a 600cfm carby
Re: 1uzfe
The A343f bolts up to it apparantly
Engineer
Re: 1uzfe
Post by Engineer »
Jerry wrote:The A343f bolts up to it apparantly
they do but you need to replace the input shaft and oil pump with the factory 1uzfe shaft n pump and then get your wiring sorted
Pedro
Re: 1uzfe
Post by Pedro »
which is about 3 wires for a manual auto, driven from the gear select indicator switch on the side of the auto, but you want to use the switch of the lexus auto as the a343f has a couple of outputs missing,
Pedro
kbushnz
Re: 1uzfe
Post by kbushnz »
Nose chops are a good option.
Comes with eng, auto, computer, dash etc etc.
You can even turn the key and hear it run.
All you have to do is fit the Transfer case.
Might cost a bit more than just a motor but its all there.
Calvin
mightyhilux4x4
Re: 1uzfe
has any1 tried keeping the lexus auto and addapting a transfer case from a surf (sounds easier on the electrics side)..
haydgq
Re: 1uzfe
Post by haydgq »
mightyhilux4x4 wrote:has any1 tried keeping the lexus auto and addapting a transfer case from a surf (sounds easier on the electrics side)..
I've got a factory Lexus auto that I brought from Wayne at the cartune company in Hamilton, he fitted the surf transfer case on the back and we have wired it to run in manual mode.
I would reccommend ringing cartune and talking to Wayne or Kelvin (07-8479969) as they know all the little tricks and whats easier etc
And all i can say is get some one like Cartune to do any wiring if you are unsure as i had a farkwit :twisted: wire up my truck who had apprently wired a few 1uz's before but he made so many fuckup's that all the factory loom and ECU were pulled out and we fitted a link.
T-Boon
Re: 1uzfe
Post by T-Boon »
If i ever get around to it, i`m gonna run a surf box, with adapter bellhousing, should be good azz.
To Boon or not to Boon.
mightyhilux4x4
Re: 1uzfe
are you meaning that the transfer case is wired to run manual or the auto its self..and is the lexus auto behind a 1uzfe
Big
Re: 1uzfe
Post by Big »
Or get a LJ70 series box off a prado.. they bolt up also but only thing is the xfer is offset.. not right for the hilux.. Have a look at lextreme.com and a bloke has converted a ssurf xfer to lexus box and worked a treat.
cher
here is the link
http://lextreme.com/forums/showthread.php?t=2367
haydgq
Re: 1uzfe
Post by haydgq »
mightyhilux4x4 wrote:I've got a factory Lexus auto that I brought from Wayne at the cartune company in Hamilton, he fitted the surf transfer case on the back and we have wired it to run in manual mode.
Hey, the transfer is a surf electric jobbie and the lexus a341-e auto trans is wired to run in full manual mode and yip its behind the 1uz in my Hilux.
