35's on a 70
Posted: Fri May 07, 2010 7:57 pm
by JR
just wondering whats needed to be done, how much lift ect. can you get away without body lift ,do they rub on the leafs at full lock? just a bit of info before i go and buy one would be good, anything else i need to know about them.
cheers all
Re: 35's on a 70
Posted: Sat May 08, 2010 8:49 am
by Sadam_Husain
you'll need some sort of lift to minimise rubbing, 50mm body lift is usually good enough and easy to do.... amount of rubbing varies vehicle to vehicle but with a body lift its usually only hard articulation that rubs, dunno about rear wheel arch rubbing coz I've only ever had cab chassis trucks. If you've got really wide tyres they might touch the springs, my 10.5 simexes never touched, I've got 12.5 creepies now but the centres have been flipped on my rims so I've gained over 50mm offset and there isnt any rubbing?
Re: 35's on a 70
Posted: Sat May 08, 2010 9:34 am
by badnuz
I ran 35/10.5/15 Simex trekkers on std 15x8 on my 70 with a 50mm body lift. they used to rub the inside rear guards, and a little on the front leaf srings under full artic... i turned the centers and fitted 25mm spacers that solved it nicely
Re: 35's on a 70
Posted: Sat May 08, 2010 5:45 pm
by JR
cheers guys, not to hard at all then.
Re: 35's on a 70
Posted: Sat May 08, 2010 6:15 pm
by mudlva
hay there
Ive just done a 50 mm spring lift on mine next week some time i will fit my 35s off my bush truck and see what happens
they are mudzillas with reversed rims running 50mm backset
will post the out cope when done
Re: 35's on a 70
Posted: Sun May 09, 2010 12:35 pm
by cruzerboy
You see the light and get a 70 john?
