Can someone help?How do you stop water from entring the electrics? Water gets in the spark plug recesses in the head shortening out the spark. The motor is a dohc and the plug leads are sealed with silacon grease. The dist cap is also sealed with silacon and doesnt let water inside but still managers to short out the leads on the outside of the cap. The dist has a splash guard and every has been sprayed wiyh CRC Soft Seal. (No I dont want to buy a diesel and yes I still want to drive thru water and mud holes)
Anyone got any ideas or what has worked for you??
thanks in advance DJ
