2lte --1kzte
Posted: Wed Aug 04, 2010 4:30 pm
by travis
Hi Im looking at converting the 2lte engine that i currently have into the 1kzte does anybody know if this is possible also if it has been done what would be involved i was thinking of changing the heads but dont know anything about these engines but dont have the mony to drop in the lexus v8 that i would like to so was going to make do with what i had but try and rebuild it in to the big brother engine that is so well known.
Re: 2lte --1kzte
Posted: Wed Aug 04, 2010 4:39 pm
by badnuz
by converting do you mean doing an engine swap?? what 4wd is it in?
Re: 2lte --1kzte
Posted: Wed Aug 04, 2010 5:08 pm
by DieselBoy
travis wrote:Hi Im looking at converting the 2lte engine that i currently have into the 1kzte does anybody know if this is possible
Completely different engines, so no you can't bastardise either.
Either buy a 1kzte, a new head for your 2lte, or, seeing as you were looking at the 1UZ, put a 3VZ-E into it, which should be largely a bolt in job as its a factory fitted engine in some models.
Re: 2lte --1kzte
Posted: Wed Aug 04, 2010 7:47 pm
by travis
so would the 1kzte bolt up to the 2lte transmition that i have in my auto hilux surf
Re: 2lte --1kzte
Posted: Mon Nov 29, 2010 6:09 pm
by surfee
hey mate did you try it im looking at doing the same thing
Re: 2lte --1kzte
Posted: Tue Nov 30, 2010 7:40 pm
by SamLogan
Hey,
Have a look around the Aussie Surf Forum (try the engine conversion section) and see what you can find
http://www.toyotasurf.asn.au/forum/
Sam
