2lte --1kzte
travis
2lte --1kzte
Post by travis »
Hi Im looking at converting the 2lte engine that i currently have into the 1kzte does anybody know if this is possible also if it has been done what would be involved i was thinking of changing the heads but dont know anything about these engines but dont have the mony to drop in the lexus v8 that i would like to so was going to make do with what i had but try and rebuild it in to the big brother engine that is so well known.
badnuz
Re: 2lte --1kzte
Post by badnuz »
by converting do you mean doing an engine swap?? what 4wd is it in?
DieselBoy
Re: 2lte --1kzte
Post by DieselBoy »
travis wrote:Hi Im looking at converting the 2lte engine that i currently have into the 1kzte does anybody know if this is possible
Completely different engines, so no you can't bastardise either.
Either buy a 1kzte, a new head for your 2lte, or, seeing as you were looking at the 1UZ, put a 3VZ-E into it, which should be largely a bolt in job as its a factory fitted engine in some models.
travis
Re: 2lte --1kzte
Post by travis »
so would the 1kzte bolt up to the 2lte transmition that i have in my auto hilux surf
surfee
Re: 2lte --1kzte
Post by surfee »
hey mate did you try it im looking at doing the same thing
SamLogan
Re: 2lte --1kzte
Post by SamLogan »
Hey,
Have a look around the Aussie Surf Forum (try the engine conversion section) and see what you can find
http://www.toyotasurf.asn.au/forum/
Sam
