RH 85-89 hilux door, no dents etc. glass, no door card. $40
LH 85-89 hilux door, large shellow dent. glass, no door card. $20
85-89 hilux windscreen. no chips or damage $40
85-89 hilux single cab ute rear window- single piece $30
1 x 90 & 1 x 45 degree 4" black rubber joiner for making tube snorkel etc $50 for pair
4 x GQ safari shocks. $60 for the set of four. front two factory, rear two heavy duty for towing boat or heavy trailer. A little bumpy at rear without load when in my GQ. Munroe rears I think but can go check.
TD42 air cleaner (used) and airbox $10
TD42 forward facing plenum. Stock base + runners with new forward facing plenum formed and welded on with 3" inlet $350 allow two weeks as welding is still being completed.
no pics yet but here is one mockup
Pair of headlights from '85-89 hilux $10
nissan GQ td42 gauge cluster....can set the kms to whatever you need before its sent $50
'85 to '89 hilux carbon fibre bonnet. Bulge is 2" + higher than factory. Must be primered, sanded and have the edges sanded/filed to suit your vehicle. Very robust and it can flex like crazy without cracking or sagging etc. Comes with 4x new bonnet pins AND brackets to mount pins in correct location at rear of engine bay. Bonnet is drilled to accept pins. $350. Selling as it wont fit new cab.
Autogauge EGT gauge to suit diesel or petrol engine. $110. Comes with sensor as seen in pic. Very nice Stepper Motor gauge. unused with manuals etc as in pic.
