pintel hook
pintel hook
Hi all i have a 70 series crusier and want to mount a pintel hook on the rear. My question is, is the rear of the chasey strong enough were the towing loop is? or would it be advisable to strengthen it before mounting the hook.Or would i be better off building brakets and mounting rated hooks in line with the chasey. All opinons weclome.
91 HZJ73 Cruiser, 4.2 non turbo,33 x 12.5 kl71's,UHF radio, snorkle, diff breathers, Factory winch, Awesome club truck.
Re: pintel hook
i presume your talking about the 4 bolt towing eye if so the pintle holes are the same .........sorta yes but i tend to make a 10/12mm thick plate to put behind the bumper so its sandwiched ie pintle-bumper-plate
the more area you cover on the inside the better
WARNING:
Re: pintel hook
Don't you sell them at work Taz
, maybe you could make him a plate as well
Re: pintel hook
as hes in chch and with a name like Sawdoc im picking he can make is own cheaper jerry........
WARNING:
Re: pintel hook
cheers taz, there is an engineer across the road from work so i will borrow
some plate and deal to it
Re: pintel hook
yeah there pretty piss weak crossmembers that bend and then add in 20-25 years of rust creeping away as well, I've got my pintle mounted on a heavy piece of channel bolted back into the crossmember and tied back to the chassis rails at each end through some brackets
edit*
chassis looks a bit flasher with some bling paint on it now
edit*
Re: pintel hook
Good stuff sadam, the channel will be better suited than the flat plate
shit thats a major transformation with at chassie, good luck with the rest of the resto.
Doc
Doc
