prado pwer-steering bleed
just going to put the power-steering all back together tomorow. been told you have to bleed it, cant be to hard so sure ill work it out. still, any tips or do's or donts would be most handy, cheers.
rough 'n' ready
Re: prado pwer-steering bleed
guess its just the same as any powersteering, go lock to lock topping it up til takes no more and is smooth.Could be wrong tho.
- skid
- Tyre Man
jack the front off the ground to do it
sometimes you dont have to, but if you end up with aerated fluid then you will have to lift front off ground and redo it
so may as well do it to start with
- flyingbrick
It will sound horrible as you do it.
Its normal
Its normal
went to fix today, but found starter had packed a sad. now thats sitting on the bench, in a hundred bits,(cheers axle
rough 'n' ready
