Hawse or Roller fairleads
kbushnz
Post by kbushnz »
O.k Guys and Gals.
I have been surfin the net and searching the forums (this one included)
I have scored some Amsteel blue rope :P to upgrade from the steel.
Now the question :?
Whats the better of the two fairleads.
So far there is a potential issue with rollers pinching the rope. Not sure how as I have tried to see it on the truck.
Possible ?? to cut it on extreme angles if it clipped the frame.
Or slipping over the rollers (no different to a hawse really.)
Or hawse getting mud on it and wearing the rope away.
I am planning on either getting a new alloy hawse or having some new rollers lathed up.
What have we all experienced first hand ! no second hand stories or myths please. :evil:
Calvin
mudlva
Re: Hawse or Roller fairleads
Post by mudlva »
have a look at this its a question that i started a while ago
http://www.offroadexpress.co.nz/Forums/ ... =4&t=21492
i must do an update as well :oops:
kbushnz
Post by kbushnz »
Thanks mudlva
I had had a good read on that one before my post. (good thread)
Had a good google search and you get both extremes.
Rollers seem the better option as the rope can roll around less resistance.
But the idea of breaking a rope from it getting pinched...??
Hmmmm.
Just after any real life experiences.
I suppose it all comes down to how you set your winch point / pull up.
Calvin
I've used both, theres arguments either way so it comes down to personal preference
mudlva
Post by mudlva »
ive gone to synthic plastic. i have been on a good run and had lots of winching the plastic has worn less than 0.5mm , as in you can just feel a slight wear spot, that happened when i did 5 to 6 straight pulls and each time the left side had a better tree
i will post photos once i get my A into G
i decided plastic over alloy on the reckoning that when alloy does wear it will create a sharp edge which wont be good
and i went away from rollers due to the chance of the rope getting caught between and pinching the rope
just my thoughts with very limited knowledge
time will tell if i choose well ah
darinz
Post by darinz »
Lots of arguements for both sides but in reality it makes sweet F A difference. With the amount most use a winch I'd just put a hawse on it and not worry about it. But I know plenty that have used standard rollers without problem. As long as the rollers haven't had wire on them then I don't think I'd bother changing. If they've had wire then at least change the rollers.
(the other thread probably is the one with huge amounts of theory about bend radius etc)
muddy
Post by muddy »
Use what you've got. I've used synthetic rope with both Landcruiser and Nissan rollers with no problems, but if you're making a winch fairlead from scratch it's probably easier and cheaper to to just make a fixed hoop. Either way, if you've had steel cable though it, make sure you smooth off any rough bits ..
Return to “Tool Shed”
