Some back ground history …. I brought a Safari back in Dec 08 for one purpose only … 4WD Touring. “Touring” meaning out for 1 to 4 weeks in the bush. So I brought a whale … LWB with high roof (she has a queen bed in the back, for me and the misses thus the high roof
The project was to make a 12V standalone system from the 24V system in the Safari. “standalone” meaning even when using all the power in the 12V system, when turning that key my Safari will always start first time! Also make sure other than some driving lights and the winch everything else electrical is 12V.
When I got the truck, the previous owner was up front and said both batteries are shot. He had been tapping 12V from the 2nd battery and if you been reading forums here you know that a no no!! So new batteries had to be brought, but also knew I would be charging a 3rd (house) battery which was to be big and deep cycle.
So the system set up:
To power all batteries and keep up with a winch / lights working very well! I had to upgrade the 35 amp alternator to a 70amp alternator. Just a quick side note, my 1st plan was to mount a 12V alternator below the original, but research and talking to people found that the low mounting got a lot of mud in it and became a continuing cleaning mission (plus no air con and my partner wasn’t too happy about that) this wasn’t a hard one, a place in Rotoura did a straight overhauled replacement for a decent price and I got reasonable bucks back from my old one. Note: the big black cable is the parallel cable to battery (goes to 50amp fuse and turns into blue cable)
To charge the house battery I got a 24V to 12V 3 stage charger unit. Note the “3 stage”. A lot of people charge a house battery with a reducer, this is a bad idea. It doesn’t drop voltage so will cook the battery in time and deep cycle one will only give out 70% power (if you’re lucky) if you don’t charge at absorption state (1 of the 3 stages is absorption). So after 2 to 3 months of searching I found a company in Auckland that does a 24V to 12V 3 stage charger @ 40amps … plenty of power for my deep cycle. (just in the last few months they now do the same unit on TM)
This unit has a small CPU that will see the 24V income and start to charge (12V output) @ 28V and stop @ 25.5V (this caused me some small issues, see below) and the 3 stage charge is fully automatic. This means when you turn off the engine the unit will shut down and isolate the 12V system, and doesn't matter how much power you use, the 24V system is always ready to start your engine again!
Next was the 12V fuse board and cut off switches. I put in 2 cut offs switches in. One isolates the charger unit with the 24V system (for maintenance / faults); the other was a 3 way switch (all off / 1 on / 1 and 2 on). I’m running a 12V compressor with tank thus the draw is around 40 amps at peek (has its own inline fuse) so I can’t go though the fuse board (fuse board is 30 amps per fuse max) so I can isolated that and / or the fuse board from battery. From those two switches I can isolate all the major parts of the system if needed. The fuse board is an 10 way, 30 amp max, 150 amp total max, this feeds all other 12v equipment needed and fused independently.
Now the setup was in … the problems start … the first problem I had was voltage drop, now I’m an electrical engineer and feel pretty competent when dealing with electricity, but I don’t deal with DC very much and the voltage drop was a bitch to find! I really did feel it was the alternator (which it was half the problem, but come to that later). The problem was the loom from alternator to battery and was resolved very quickly with a blue 12mm core cable (fused 50amp) running from the alternator (the black cable) to the battery (the blue cable) direct. Now I had the 28.8V @ 1200 RPM!
Next was the problem of not getting 28V at 600 RPM. The alt would only give 28V at 1200 RPM. Now this was causing the problem of every time you stooped at a set of lights or roundabout the unit would go below 25.5V and turn off, then you accelerated it would go over 28V and turn on. Now this constant on / off doesn't do you charger any good, and could perpetually burn it out.
I also wanted 600 RPM as most trips we are 4WD driving in somewhere and then walking for a few days, to and back to camp, so we need power for around 3 to 5 days. Now the battery will run without charge for 3 to 4 days but good if you can charge it before this. So I wanted to put truck on tick over and charge without driving anywhere (good for camping also).
So to fix I put a small pulley on the alt that got it down to 800 RPM @ 28V. I'm hoping in the next few weeks to do my injectors which fingers crossed give me the 200 RPM I need to have the alt at 28V at tick over of 600 RPM. Will post up when I get injectors done
Would like to hear what others have done for a 12V system, I know of a few that have done for more power to winches and such like, this set up is more of an RV setup.
Any questions or electrical problems happy to help, as I'm going to be doing the engine side of the truck this year and as being electrical I will be asking a lot of questions as I don't that side
Also anyone in Christchurch area who has done any turbo set ups who fancy giving us some pointers would be great!!
