1KZTE into Bundera
1KZTE into Bundera
I have aquired a 1kzte & auto trans out of a kzn185 surf. I am planning to put the motor & hopefully trans into my Bundera. Has anyone grafted the split case transfer case on to the back of the A343H trans that is in the kzn185 or should I be looking at another way?
Re: 1KZTE into Bundera
Get a transfercase and the tail section of the auto from a one of the early 3L or 2.4 Prado's
The autos are all from the A340 family and should all bolt up.
Calvin
Calvin
If thats the case I might as well use the entire trans from an early prado & just change the bellhousing.
True.....Sort of....
If you get the 2.4 2LTE then yes.
If you get the 3.0 1KZTE...then you have solved your problem...
Dont forget the ECU! It controls the engine and Auto..
I have a 3.0 1KZTE in my square Prado...
Calvin
Calvin
Is your truck imported from Auz? a real Bundera or is it a LJ71 Prado?
It's an early pre Prado LJ71 Bundera with 2LT motor & R series box. My other option is to source a solid mass flywheel & clutch. I'm getting rid of the ecu & putting the fuel pump out of my 2lt in it. If I stick with auto trans I'm going to have to manually switch gears. Has anyone done this?
Mine is badged as a Prado, don't forget pics
Yes people have done manual controls for the auto.
Most do it when they swap in the 1UZFE and auto...
I am sure someone can suggest who to goto..
Calvin
Calvin
"84- "87? was pre Prado. The trailing arms are different, so is the shock setup
PS, I'm new, how do I insert pics?
Jerry wrote:Mine is badged as a Prado, don't forget pics
What's the model number of the bundera?
Who knew Prados could fly?
I know this isn't going to help, but I've found two types of transfer cases on the auto boxes (not counting that wierd KZ one that drops on the wrong side) I've had the parts boy at toyota conferm differance in internal parts... unfortunaly I didn't get a chance to measure up input shafts etc and just to make it more difficult the cases look identical, the only reason I know the diff is the guy who I sold it to is a mechanic he picked it up when he tried to swop parts to make one good one
As for manual"ising the trans its been done alot in the states, you can buy plug in computers... and I was planing on doing this to my next project after I've got it going
As for the standard comp for the auto... I don't know how that will go as its in the engine ecu, I know the engine will go into limp mod if there is no feed from the comp... makes me wonder if it works the same was for the trans, you could look at fitting a stand alone trans comp out of a surf
If your interested, clive might have mentioned I've got an auto transfer case apart on the bench at the moment, I only want the low box out of it, so I could put it back together for you and swop you for the KX one... if it fits
As for pics dead easy post them up on a site like Photobucket.com and then copy the link and post in between the "img" tags
Cheers Reece
Cheers Reece
A 185 Auto needs a 185 transfer case for it to work. The 130 transfer case (drivers side drop) bolts up to the 185 auto but the splined shaft is too short so to put a 130 transfer case behind a 185 1KZ you need the 130 auto as well.
We know this from a friend who did a beam conversion to a 185.
Re Reece's comments
You can use the trans computer out of a Jeep Cherokee for the A343 Auto, worked great on mine and was only $80 from a jeep wrecker.
If the auto part of the Engine ECU doesn't go, you will need to use the lever and you will get:
1 - 2nd
2 - 3rd
3 - overdrive
You will loose 3rd gear. Or at least the A343 in my Prado did without a comp.
1 - 2nd
2 - 3rd
3 - overdrive
Cheers for that NJV6 looks like I don't need to put mine back together
anyone know about the Asin 30-80 out of the Isuzu Mu, it was longer in the housing part of the transfercase.... bolt pattern looked to be the same
hey WJW did you replace the electronic selector on the side of the case with the ecu.... just I remember them being different with the different vehicles they've come out of
again not something I ever thought to pay attention to
Just cuirous as I've got a trans here that I was planing on useing (60% certain its come out of a YN130) but no loom or comp... been keeping my eye out for surf computer... as this is a fair bit down the project list I havn't done much research yet anyone know if there is any differance on the computer maps for the diesel vs petrol or was the differance managed with different torque converters.... hmm might be time to start doing some research
Sorry for the hi jack JJ
Cheers Reece
Cheers Reece
There are literally hundreds of variants of the Aisin trans, In Jeeps they are AW4's in Toyota A34x etc.
The ecu's for both the A343F (Prado) and the a343H (Surf) are pretty much the same, its the transfer case 4wd selection and output shaft offsets that are different. Not sure if you could bolt up a surf TC to a Prado auto though.
You can use a Jeep AW4 ECU to control the auto, from memory there are two versions, I could only get a mark 1, but the mark 2 gives better fuel economy.
Off subject, but how did you do that & so fast
copy the image location into thread and then use the img button
Cheers. Back on subject. I'll come and look at what you have got sometime Reece, but it is looking more like I may have to find myself a cheap flywheel from somewhere & just use my manual box as I also have a pto whinch to contend with as well.
I'll be down CHCH later this week for work, other than that any time
BNT do a solid flywheel conversion for the 1KZ I've fitted a couple of them now, last pricing they were the best
I'm planing on running a pto winch off the auto... don't know yet if this is going to be a good idea but I've got it sitting there so might as well give it a try, if it fails
I'll convert the pto to a cheap version of hydrolic
Cheers Reece
Cheers Reece
It works. You just have to control the pto running on with the torque converter., so you need to lock the trans before engaging & disengaging the pto.
can't you just get a prado transfer & auto and use the standard toyota PTO bits?
Yes I could. I got the kzn trans for nix with the motor so was hoping to graft on the LJ71 transfer case to save cash. But its starting to look to hard. Trying to come up with cheap easy options but as we all know nothings cheap when building a truck.
jj1959 wrote:I'm getting rid of the ecu & putting the fuel pump out of my 2lt in it.
I'm currently investigating a manual fuel pump conversion for my 1kz-te
My research currently says that it is not quite as simple as just bolting up a 2lt pump and winding up the fuel .
Apparently you need a modded 2lt-e pump body, a landcrusher pump top / boost compensator and modified 1kz pump internals.
Then some one with the nouse and tools / workshop to set it up properly so you don't proceed to melt the pistons .
I'm budgeting around the 2k mark to properly and reliably do this mod
LR110 ..... LJ50 project
You are correct. You can't just bolt them in & wind up the fuel. There is afew other adjustments you have to make. I've got a friendly Diesel mechanic thats done a few of them now so I will just hand my pump to him.
Already have the pto & winch. Just trying to do the engine conversion now.
Has anyone got a tailshaft adaptor for a KZJ78 auto trans lying around that they might want to get rid of?
I'll check if Ricks going to use the one from mine.
