Ok heres the go..
Some months back I had a line burst in the brakes... Pedal went soft and to the floor.
Changed the hoses and also changed the master cylinder seals and full system bleed. Starting with Master cylinder and then working my way around from rear to front.
New fluid flush etc etc.
Pads all good and no binding issues.
Brakes felt the best they have in years....
No heres the kicker.
After a days 4x4ing (not hard yakka) the trip on the way home on highway the brakes apply at just the gentlest push of the pedal....
Normally you get some slight softness as you push the pedal till they slowly apply pressure... but it just comes on strong from the go.
By the time I get home they feel "normal again"
I think it may be an issue with the booster but its strange that it still brakes good... no extra effort required.
Any ideas??
Calvin
