2.4L TD Hilux Problems
Hey guys, new here. I have a problem with my new hilux.. well. The 4wd doesn't engage, i've checked the plugs to the front diff etc. Not sure what else it could be. is there anything to definatly check to make sure its nothing serious? Thanks
Re: 2.4L TD Hilux Problems
surf or hilux? ifs or solid front? what year? manual or auto hubs?
J_Dub wrote:surf or hilux? ifs or solid front? what year? manual or auto hubs?
oohh, good questions. haha, its a 1992 hilux surf, auto, has the vaccuum operated 4wd...? i think? has a button on the side of the high and low gear stick..
Are you hearing a click sound near the lever when you press the 4WD button? From memory there are a couple of relays in the console that close in and out as you activate 4WD. That might indicate a power failure (fuse?).
I don't recall where the two vacuum solenoids are in the engine bay, but trace them back via the vacuum hoses and make sure you have no splits or cracks in the hose too.
Steve
Steve
- dave_ln130
- Bush Crasher
the vacum points are drivers side in the engine bay there are two of them there is also a vacum line going across the engine were the turbo pipe is make sue that is still all good and the points it plugs into i misplaced this when i replaced the joiners on it and it did just this ahem
SupraLux wrote:Are you hearing a click sound near the lever when you press the 4WD button? From memory there are a couple of relays in the console that close in and out as you activate 4WD. That might indicate a power failure (fuse?).
Steve
nah no clicking aye, throw it into neutral then into low 4wd, button on too, and no noises at all, would that mean its a power fault somewhere ?
sounds that way... check the fuses, then start pulling the console apart and check the wiring is still intact...
Failing that you probably need a multimeter and some knowledge...
Check the clip on the transfer case (about halfway underneath, you can access if you slide under). Mine has a busted clip on the plug and popped off causing this exact problem.
027 MUD GEAR - (027 683 4327)
Check our facebook:
SupraLux wrote:sounds that way... check the fuses, then start pulling the console apart and check the wiring is still intact...
yeah i took off the centre console and ran through the wires and all from the high/low gear stick and all of them looked/seemed fine... is there anything known to blow or break on these?
uwshho wrote:Check the clip on the transfer case (about halfway underneath, you can access if you slide under). Mine has a busted clip on the plug and popped off causing this exact problem.
is this the plug that goes into the back of the front diff? if so, yeah i took it out and cleaned it out replugged, did the same for the plug at the front of the diff.. still no changes.. seems to be a tough fix..
I'm out of ideas - might be time to pop into an autosparky...
Steve
Steve
took a look with a multi meter and theres no power at a solenoid. fix time.
