Swivel hub kit prt numbers
Posted: Tue May 10, 2011 5:16 pm
by Taz
Hey.
Anyone got a list of part numbers for the seals and bearings in a swivel hub kit for a Y60 Patrol/Safari?
Thanks,
Taz.
Re: Swivel hub kit prt numbers
Posted: Tue May 10, 2011 5:22 pm
by coxsy
terrain tamer kit SH13
Posted: Tue May 10, 2011 6:39 pm
by Hombrey
Hmm will check mate. Got mine as a seal kit and also did king pin bearings etc. From memory the kit was around $300 but that was nearly cheaper than buying axle seals on their own (about 90 each or something terrible) and you get those seals as well. Got the kit through BNT automotive.
Posted: Tue May 10, 2011 9:13 pm
by coxsy
yes comes with seals bearing very good kit hub gaskets to , slow reply son on pc
Posted: Tue May 10, 2011 11:15 pm
by charo249
I can also recommend the BNT kits - have axle seals, swivel hub seals and bearings and front diff gasket
Posted: Wed May 11, 2011 2:22 am
by albundy
can also vouch for terrain tamer kits, cheaper in the long run as opposed to genuine nissan.
Al
Posted: Wed May 11, 2011 4:10 am
by Taz
Cheers for the help. I meant individual part numbers though. I'm just gunna grab a kit from BNT (bout $260 iirc) and note them down for next time. Should be cheaper to piece it together myself from SKF or Saeco.
Posted: Wed May 11, 2011 4:16 am
by Taz
albundy wrote:can also vouch for terrain tamer kits, cheaper in the long run as opposed to genuine nissan.
Al
I never bother with genuine. After working for a dealer for a little while (not Nissan mind you) I know enough behind the scenes to know not to bother.
Everyone has to make a dollar, it is how life works, but dealers take the piss on stuff like this that is usually not even single application.
