Swivel hub kit prt numbers
For all Nissan related topics
Taz
Post by Taz »
Hey.
Anyone got a list of part numbers for the seals and bearings in a swivel hub kit for a Y60 Patrol/Safari?
Thanks,
Taz.
Re: Swivel hub kit prt numbers
terrain tamer kit SH13
Hombrey
Post by Hombrey »
Hmm will check mate. Got mine as a seal kit and also did king pin bearings etc. From memory the kit was around $300 but that was nearly cheaper than buying axle seals on their own (about 90 each or something terrible) and you get those seals as well. Got the kit through BNT automotive.
yes comes with seals bearing very good kit hub gaskets to , slow reply son on pc
charo249
Post by charo249 »
I can also recommend the BNT kits - have axle seals, swivel hub seals and bearings and front diff gasket
albundy
Rolly Polly
Post by albundy »
can also vouch for terrain tamer kits, cheaper in the long run as opposed to genuine nissan.
Al
Taz
Post by Taz »
Cheers for the help. I meant individual part numbers though. I'm just gunna grab a kit from BNT (bout $260 iirc) and note them down for next time. Should be cheaper to piece it together myself from SKF or Saeco.
Taz
Post by Taz »
albundy wrote:can also vouch for terrain tamer kits, cheaper in the long run as opposed to genuine nissan.
Al
I never bother with genuine. After working for a dealer for a little while (not Nissan mind you) I know enough behind the scenes to know not to bother.
Everyone has to make a dollar, it is how life works, but dealers take the piss on stuff like this that is usually not even single application.
