ifs
poss682
ifs
Post by poss682 »
anyone got any ideas on how to get more flex out of ifs
Smurf
Re: ifs
Post by Smurf »
gas torch :-)
then SAS.
Other than trimming your bumpstops and removing your sway bar, there isn't a lot you can do
bda4130
Re: ifs
Post by bda4130 »
Yeah, sas it up! It's a bit of a mission but end result will blow your mind :shock:
rangimotors
Re: ifs
Post by rangimotors »
na the more flex you get from the ifs the bigger the angle on the cv's and the more you shag them. Better to accept the fact that they just don't flex and 10mm more isn't really going to change that. Buy a front locker and lifting a front wheel won't matter aqs much.
suzolla
Re: ifs
Post by suzolla »
Hi,
See http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=64&t=19572 if you are keen on a locker.
Tim
mike
Last minute Mike
Re: ifs
Post by mike »
There are about 2-3 times max that I have wished I had a SAS in my surf in the 5 years I've owned it. The front locker has seen me through the other 99.7% of 4wding with ease, the other times just required more thought to get through. I still have no desire to SAS it, the IFS is comfortable, easy to fix and parts are so cheap or free (because everyone else is sasing them they dont want the parts)
I put twin auto lockers in 4-5 years ago and have had the best touring 4wd I could have ever wanted.
just my 2c.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
tallsam66
Re: ifs
Post by tallsam66 »
mike wrote:There are about 2-3 times max that I have wished I had a SAS in my surf in the 5 years I've owned it. The front locker has seen me through the other 99.7% of 4wding with ease, the other times just required more thought to get through. I still have no desire to SAS it, the IFS is comfortable, easy to fix and parts are so cheap or free (because everyone else is sasing them they dont want the parts)
just my 2c.
I agree ....i love my IFS.
Not had any problems ...Ive got a rear locker that makes my surf so much more capable.
I just love driving through stuff that other much more capable vehicles get stuck in !
KIWI_TERRANO
Re: ifs
Post by KIWI_TERRANO »
Twisty in Ozhad a 1uz 4runner on 37s and its still ifs with 4inch suspension lift and 2.5 body, He doesnt break stuff.......
NJV6
Re: ifs
Post by NJV6 »
IFS + Front locker = :mrgreen:
tallsam66
Re: ifs
Post by tallsam66 »
A guy in chch is running 42" tyres on IFS...but only gets driven on the rd
getsum
Re: ifs
Post by getsum »
tallsam66 wrote:A guy in chch is running 42" tyres on IFS...but only gets driven on the rd
because of the quake damaged roads or to drive over boy racers?? :lol:
KIWI_TERRANO
Re: ifs
Hopefully boy racers as the main reason :lol:
SupraLux
Complete Bastard
Re: ifs
Post by SupraLux »
poss682 wrote:anyone got any ideas on how to get more flex out of ifs
There was a posting on an Oz forum a few years back about making spacers to go between the top a-arm and the ball joint which gave them a better range of motion - someone here made some... have a search around, there were pics of it as well.
mike wrote:I put twin auto lockers in 4-5 years ago and have had the best touring 4wd I could have ever wanted.
Mike, you only put the rear one in for drifting on gravel roads :mrgreen:
KIWI_TERRANO
Re: ifs
Advantage 4wdin chch pretty sure he in ph book, when i still had ifs surf bj spaces were 130 i think
getsum
Re: ifs
Post by getsum »
i saw a few pics of someone in the states that lifted a 2wd courier by balljoint spacers...they were about 200mm :shock:
was the same height as a stock proceed...not bad for a 2wd..haha
might have to investigate these spacers for my surf 8)
KIWI_TERRANO
Re: ifs
If you cant find his number then give me a pm and I will try find it and get in contact with him
getsum
Re: ifs
Post by getsum »
hope this isnt against the rules but check this out
http://www.4crawler.com/4x4/ForSale/Bal ... acer.shtml
tallsam66
Re: ifs
Post by tallsam66 »
Worzel made someball joint spacers ...but they wont actually give you anymore "flex" only make it higher means you can get some lift with out having to adjust the torsion bars.
The only way to get more flex is to trim the bump stops & thats illegal if you still want to drive it on the road.
KIWI_TERRANO
Re: ifs
tallsam66 wrote:Worzel made someball joint spacers ...but they wont actually give you anymore "flex" only make it higher means you can get some lift with out having to adjust the torsion bars.
Makes more space for down travel aswell...
getsum
Re: ifs
Post by getsum »
you can probably get hold hold of lower profile bumpstops aswell..
KIWI_TERRANO
Re: ifs
I also had trimed bump stops in my terrano front and back and never had wof issues.......
Think 2wd bump stops are smaller in toyotas
even better do a sas like i did to my surf
UBZ
Re: ifs
Post by UBZ »
I've got some 1" ball joint spacers sitting at home. New never fitted if your interested.
bda4130
Re: ifs
Post by bda4130 »
I just shaved 8mm off my bump stops and this is the result.. :lol: :roll: :lol:
UBZ
Re: ifs
Post by UBZ »
bda4130 wrote:Image
:o :shock:
you put leaf springs in the front of a Coil sprung truck :!:
I'd perfer my IFS . if your going to SAS a surf at least do it with coils.
KIWI_TERRANO
Re: ifs
I know leafs is cheaper easier but sorry I totally disagree with it.
Coils front and rear or keep it ifs.
Personally dont see advantage of leafs over ifs
With 35s and short shocks this is how mine flexs, now with longer shock (sorry no photo) be more but yer cant see leafs getting the same flex and ride
http://www.offroadexpress.co.nz/4wds/95-kzn130-surf
bda4130
Re: ifs
Post by bda4130 »
KIWI_TERRANO wrote:I know leafs is cheaper easier but sorry I totally disagree with it.
You driven one? Flex is amazing and on road handling is at least as good as when it was ifs.
KIWI_TERRANO
Re: ifs
Two of my mate have set ups like that and a mate has rear coil and leaf front in hilux, would prefer surf anyday and my fex is still inchs better than there even betterb now with longer shocks
bda4130
Re: ifs
Post by bda4130 »
Okay, that's fine, but 5-7 inches of travel(ifs) can never compete with the almost limitless travel that can be achieved with a solid front axle ( coil or leaf) :D
rokhound
Re: ifs
Post by rokhound »
UBZ wrote:you put leaf springs in the front of a Coil sprung truck :!:
Why?
If from a road going point of view I get it,(comfort wise etc)
but you can get as much (and sometimes more)artic from leaf springs as you can from coils.
And if anyone needs proof of that, they should remember suprasurfs last truck (and there are still plenty of people on here that were around then!)
The yanks seem to be ripping out the coils and leaf springing the whole truck, not saying that is right or wrong, but if you are just going to bang a front end in from a coiled playdoh (or similar) using factory arms and mounts then you are only going to get the equivelant travel (basically) that one of these rigs offers which is not great imo.
To link up a front end properly requires a lot of time studying geometry etc for your particualr purpose. But to bang a set of cart springs in is relatively easy and making a spring pack to work is pretty straight forward.
Each to their own though.
KIWI_TERRANO
Re: ifs
bda4130 wrote:Okay, that's fine, but 5-7 inches of travel(ifs) can never compete with the almost limitless travel that can be achieved with a solid front axle ( coil or leaf) :D
Yer mine is a coil set up, and will always flex more than ifs
Leaf gives (in my opnion) a harsher ride and less flex than a coil set up.
But at the end of the day it up to the person and there budget
also think about this
vx cruiser coil f and r
70 series flat deck coils front leaf rear,
if you can tell me a manifacture that does leaf in front and coil rear from factory i would be dumb founded, they do suspension set ups like it for a reason
