wrecking out a 2dr surf,let mew know what you need and what your willing to pay for it,never know you may even get some bits cheaper
got full shell glass tinted and non tinted set couple of tow bars front bumper lights rear diff housing ie drum to drum and most other fiddley bits etc
also 4dr front seats
all good caleb,ive got 2 here so just get back to me when you can and hopefully ill still have one available,that or I can fab one up to suit for a reasonable price
and terranoman31,um i could do rolling chasis (if you supply some wheels) for say $300,that for chasis and full rear diff setup along with front end minus shocks and cvs and also no manual or auto hubs
and can now add a 250000km ruff running 2lte motor,not interested in parting unless for the right money,motor hadn't been running n a year or so and had old diesel so a service of oils,filter and fresh diesel and a good run and id say she wouldn't actually be that bad.did only get it running long enough to check turbo,injector pump and alternator were all good which they are
bump,want the 2dr shell gone now so i have space to get my build sorted,make an offer,ill get 100 for cutting it up and scraping so bet that and she's yours.it really will be a waste if i do cut it up as its straight
ok now ive got my donor body off the new truck i have another chassis and bottom end.fronts a 4.5ifs add diff,rears just the housing,no diff head,all arms etc there,no drive shafts either,anyone interested?300 for the lot or i can split it up?maybe some ones interested in the rear half cut to coil there project or whatever etc,let me know
