Hey guys im looking for a transfer case and front diff assembly from a nissan safari.
specificly a diff out of a 2.8ltr spirit, with the 4.6:1 ratio. but if i cant get one of these any safari diff will do.
i will need the following:
auto t-case,
front diff,
drive shaft,
steering setup minus steering box.
cheers guys
Wanted: Safari Diff an T-Case
Re: Wanted: Safari Diff an T-Case
I'm keen to see how available those 4.6:1 diffs are as well and how much they want for them.They seem to be a bit thin on the ground.
Pm quadstyle he had a rollin chassis for that model for sale a while ago
ok i found the diff i just need a transfer case now,
it suprised at just how dificult it is to find one...
rang outback 4x4 in waikato and they have a transfer case for $700 including freight, so if anyone else has a better offer?
PM Toyoda, he has a T.Case attached to a Auto sitting in my shed, he may part with it for the right $$$
cheers for that dieselboy
ok,
so i have found a manual transfer case all i need is the adapterplate that goes between the auto trans and the transfer case.
the diff and driveshaft,
the steering setup will have to be made up,
- KIWI_TERRANO
Cant wait to see this conversion done
well its slowly coming along, i want it done by august so its not too far away.
