A bit of history on the truck, its a 130 surf chassis with a lj78 prado front diff, its runs the factory 78 series Prado front calipers/vented rotors and ive fitted the Mr2 calipers on the back end with rear 78 series prado discs. Its got new pads and rotors all round and ive also fitted a brake booster and master cylinder from a 95 series Prado to cope with the disc/disc set-up i now have.
Ive fitted new copper brake hard lines and new flexi lines were needed and the brakes have been bleed propally aswell.
It doesnt help that im trying to get the brakes sweet running 35in simexs, i need to get the cert on my simexs as they are on my Beadlocks that i also need certed etc
Are the v6 surf calipers any better/bigger than the 78 prados and is the 80 series cruiser booster/master cylinder any better than the 95 series Prado one im using, the Prado one is a 1in bore and i thought if its good enought for a LWB kzn95 Prado then it should work on my 65 series Lux.
Also what normally happens when fitting a master cylinder with the bias built in to suit the rear brakes.? as ive still got the funny proportion valve set-up that the drum brake Surfs use.
It pulls a little to the left so ill rebuild the front calipers but first wanted to know if the v6 surfs ones are any better.
Cheers for any help its appreciated.
