Hi all.
I need advice and parts to convert my auto HJ62 Landcruiser to manual. It is currently running a 2H engine with an aftermarket turbo setup.
I have read that an H55 gearbox and bell housing is the one to use. Does anyone have one of these for sale?
I will also need a clutch fork, thrust bearing, race, and the pedal box setup.
Any advice would be much appreciated.
Liam G
Need parts and advice - HJ62 Landcruiser, Manual conversion.
- ClassicCruiserSpares
- Sausage Shack
Re: Need parts and advice - HJ62 Landcruiser, Manual conversion.
Hey dude, would pay to put your location into your profile so makes it easyier for us to help you.
Yes the H55f is the gearbox you need but there are a few different versions of it, fine spline/coarse spline etc.
You will need a 2H manual bellhousing because the 3b ones are different, Maybe a 12h-t manual one mite fit? Youll need driveshafts and crossmember too.
Thanks heaps, I'm in Manakau in the Manawatu region near Levin. If anyone has or knows of where i can get some of these parts for a reasonable price that would be most appreciated.
