mayday wrote:Now for the questions! I have the transfer in bits so i can install the pto gear to drive my winch, It seems pretty easy so far but I do remember a post on here detailing it that seemed really good. It might just be me but the forum search function here is annoying and I cant find anything!
we did my flatdeck one a few months back, easiest way to do it is to stand the trans on end so its easier to work on, just follow your nose and its pretty simple, you'll need the short spacer as well as the drive gear
mayday wrote:Also can the transfer operate in low 4 without the vacuum solenoid set up?
without the vacuum diaphram you'll only get L2
mayday wrote:
Ive seen a few 70s on here with 350's but would be keen to see some pics of your alternator/power steer setups
power steering you just use a std chev power steer pump and get a hose made up to fit the Toyota steering box, there are heaps of different alternater setups, up high on the drivers side is pretty standard and helps keep them out of the mud
havent got an alternater pic handy (edit: check out my avatar) but heres a standard chevy power steering pump setup, they usually mount off the waterpump in a little cradle bracket
mayday wrote:and also any pics of the engine mounts you guys have used as Im starting from scratch.
I first started off with one of these in my flatdeck, it bolts onto the front of the engine around the timing cover and picks up the origional cruiser mounts but it twisted and I was always breaking bolts and the engine would rest on the firewall, I think Wop is still using the same type of setup and hasnt had any problems so far
I ended up geting some captive mounts made up, they were made for a standard 3 bolt chevy setup but have now been modified for a later engine 4 bolt pattern
My 40 series cruiser has had new brackets made up and uses standard chev engine mounts
