I've over ordered on high steer arms
let me know if you interested in a set.
Trail Gear brand and RHD.
http://www.trademe.co.nz/Browse/Listing.aspx?id=391443753
Discount for ORE...
Trail-Gear is the originator of forged high steer arms for Toyota Pickups and 4Runners. Each arm is pressure Forged from 8620 tool steel, these arms are incredibly strong. Because we make them in lots of 1,000 at a time we can offer these at a great low price!
All mounting surfaces are machined including the split washer surface and the tie rod tapered holes, ensuring correct and positive contact between parts, preventing knuckle studs and tie rod ends from coming loose. Arms are angle compensated so that the rod ends ride at the factory designed 90 degree angle.
Fits 1979 - 1985 Toyota pickup and 4Runner. Also fits 1979 and later Land Cruisers with spring over conversion
TG High Steer arms F/S
Re: TG High Steer arms F/S
other than the high steer arms what else is needed for a high steer conversion
and what would the total cost of the conversion be around
just tinkering with ideas at the moment
1980 4x4 Hilux Restoration
- muddyhilux
i am going to need these in the future at some stage,what do you mean by discount?
,i think im very interested,just got get some cash together
tintin wrote:other than the high steer arms what else is needed for a high steer conversion
You also need an IFS steering box, tie rod, Draglink and the required tie rod ends etc. Do a google search, there is lots of info about this floating about.
Thanks Rok, I didnt fancy writing that..
