Where to find Flasher relay 70s Prado
Looked for the flasher relay, ended up removing every other relay but still can't find that flasher unit, any ideas.
Re: Where to find Flasher relay 70s Prado
under the drivers side right
Looked up above the steering column, can hear it but can't locate it. need to know exactly where it is.
If your sitting in the drivers seat, it will be facing the side of the steering column, tucked up behind the front dash fascia, just by your left knee. it has a black cover over it so not easy to spot.
Who knew Prados could fly?
Have a look at this link for the KZJ78....
http://www.toyodiy.com/parts/p_J_1994_T ... 401.8.html
Item 81980
Even can see its P/N 81980‑50010
Calvin
Item 81980
Calvin
i would say right next to the eater core drivers side.. there is a little bracket that has a few relays and i'm sure the flasher unit..
