Diff pinion??
Posted: Thu Oct 20, 2011 7:36 pm
My D21 developed quite a loud whine when it got above 50kph and when I went to drop out the rear drive shaft I noticed the pinion shaft was very loose. The nut is still on tight...
Am I better to try and fix the bearings and what ever else could be stuffed or just buy a second hand diff head once it gets too bad to drive?
