Diff pinion??
For all Nissan related topics
willyd
Diff pinion??
Post by willyd »
My D21 developed quite a loud whine when it got above 50kph and when I went to drop out the rear drive shaft I noticed the pinion shaft was very loose. The nut is still on tight...
Am I better to try and fix the bearings and what ever else could be stuffed or just buy a second hand diff head once it gets too bad to drive?
kbjj
Re: Diff pinion??
Post by kbjj »
If your bearings are sloppy, your crown wheel and pinion are not correctly meshed and wearing excessivly. Another diff head asap imho
