My surf has recently been raised 2-3 inche's.
Since then i have a slight vibration at low speed, Im thinking maybe it's the angle the drive shaft is on?
Any one know or had these problems?
Kzn130 slight vibration
- tomsoffroad
- Flopsie
Re: Kzn130 slight vibration
Chances are your driveshaft universal joints will need replacing. They tend to wear into a 'groove' then when you lift it your making them work outside of that groove if you know what I mean
Cheap and easy to replace tho.
Oh sweet so best to do both ends of the drive shaft?
