Landcruiser 80series Wheels ? 15x7JJ (10 )
Can anyone help me, I was sent a set of Alloy Toyota Mags only to find that they don't fit
As far as I can tell they my be off a 1990>92 80 series Cruiser, the numbers on the wheels as 15 x 7 JJ ( 10 ), If you have a VX could someone check these numbers for me,Thanks
- drive it ...
Re: Landcruiser 80series Wheels ? 15x7JJ (10 )
Probably no help to you - my 93 prado (78 series) says 15x7(-20)
Presumably the ( ) is the offset.
Yes Prado 70series are (-20 ) which is what I was after, all sorted now, but want to know what these other rims are off. Kevin
- MNC
oldblue wrote:Can anyone help me, I was sent a set of Alloy Toyota Mags only to find that they don't fitAs far as I can tell they my be off a 1990>92 80 series Cruiser, the numbers on the wheels as 15 x 7 JJ ( 10 ), If you have a VX could someone check these numbers for me,Thanks
Pretty sure this is what I used to run on my old LWB Safari (gold ones).
Cant confirm cause its loooong gone.
- ClassicCruiserSpares
- Sausage Shack
MNC wrote:oldblue wrote:Can anyone help me, I was sent a set of Alloy Toyota Mags only to find that they don't fitAs far as I can tell they my be off a 1990>92 80 series Cruiser, the numbers on the wheels as 15 x 7 JJ ( 10 ), If you have a VX could someone check these numbers for me,Thanks
The gold saf ones are steel not alloy though
Do you have a pic of the wheels?
Tryed to upload photo from Photo bucket, can't get it to work.
the factory wheels on my 95 VX are marked 16x8JJ 0
Tony
Tony
Tony.
- firestonecruiser
if they are 15x7 with a positive 10 offset they have come of an ifs 4x4
- skid
- Tyre Man
more than likely surf wheels dude, especially with that positive offset
like these ones..............
From what I have seen, same style as in Photo Thanks
70 series Prado wide track 15 x 7 JJ (-20 )
IFS Surf 15 x 7 JJ (-8 )
1990>1992 VX Cruiser 15 x 7 JJ ( ? )
Cruiser wheels are silver painted where as Surf are clear coated polished alloy.
- skid
- Tyre Man
what model (year) 80 are you trying to fit them to
just dropped off a car at a customers and there was an 80 there with the above wheels on them and they were stamped 15x7JJ (10)
later model 80s had 16s factory to fit over larger brakes on the front
Thanks Skid, Want to sell them but needed to know what Cruiser they came off.5off
