ln61 surf gearbox cross member
- BeamedSurf
- Bush Crasher
I am taking the engine and box out of my ln61 surf, i want to do it with the box still attached to the engine to make it loads easier. I'm having trouble getting the gearbox cross member off as it has 8 bolts that attach it to the chasis (4 each side), and 4 bolts that attach it to the gearbox itself, the bolts onto the gearbox are rather difficult to get to, it seems that if you take the front driveshaft off that it will make it easier to get to some of the bolts but in order to get to the drive shaft bolts on the transfer case end you have to remove the cross member first =/. someone please help
Toyota Hilux Surf SSR LN60 Beam Axle
Build in progress
Build in progress
- BeamedSurf
- Bush Crasher
Re: ln61 surf gearbox cross member
sorry, you can get the 2 left ones out but the right 2 wont come all the way out because the mount has a flange thing that sticks out blocking the bolt from coming fully out
Build in progress
Build in progress
there are 4 small bolts that bolt up through the bottom of the cross member into the bottom of the gearbox mount, you may find it easier to undo these and leave the mount attached to the gearbox
- BeamedSurf
- Bush Crasher
ahh thankyou =D, so the gearbox should be fine just sitting there unsupported apart from the engine thats holding it in place?
Build in progress
Build in progress
i got to do this on my ln130 as well so when i figure it out i could give ya hand if ya spoem advice if ya want
- hosehustler
Not really it puts a lot of stress on the engine mounts, put a an axle stand or something similar under the g/box or trans case to support it.
I hate signatures
- BeamedSurf
- Bush Crasher
thanks for the help guys, much appreciated
Build in progress
Build in progress
Ok
So me and a mate did this today in around 40 mins .
trolly jack/axel stand
17mm socket
12mm
breaker bar
CRC
Step 1.
CRC the crap out of it the night before.
Step 2.
4 bolts holds the trans to the cross member take them out.
jack the trans up about 2 cm.Take of the muffler mount too.
Step 3.
undo the 8 bolts holding the cross member onto the chassie with the 17 and a breaker bar.
Then do the same agian but start from step 3 lol.
its piss easy
17mm socket
12mm
breaker bar
CRC
Step 1.
Step 2.
Step 3.
its piss easy
- BeamedSurf
- Bush Crasher
i got it off bout a week ago now lol
Build in progress
Build in progress
