turbo change
turbo change
So i think my turbo may be on its way out ......
burning abit of oil smoking ect...
2lte engine can i put a bigger turbo on it ? if so what model ect?
Found anthour place that can intercool a 2lte and it looks bloody easy .
i know it needs a 2 -2.5 exhaust wers the best place to get one?
- crazyclark31
Re: turbo change
to check it take the air intake from filter off and grab the wee nut. If there is any in out movement or heaps(more than a mm each way) thenyeh is on its way out.
A good upgrade would be the ct20b. afaik it bolts straight up. and go a good size front mount.
Re: turbo change
For your exhuast Uniweld on mainsouth rd around the corner from 4wdacceseries is pretty good to deal with reasonably priced too
Re: turbo change
as a 2lte doesnt it already have the ct20 ? or is a ct20b anthour type of turbo ?
Re: turbo change
2lte uses the ct20, the ct20b is found on petrol motors and is not a straight bolt in.
would like to know the easy way to intercool a 2lte tho.
- KIWI_TERRANO
Re: turbo change
depends what model surf 2lt you have is it efi and newer than 90?
Ct20a came out on pre 90s and then they brought out the ct20b it has different inlets outlets for water cooler and the turbo is visably differently looking, but still same mounts and size. the bs have a bigger wheel by 2mm which is f all. no point using petrol turbos or they wont boost to to late.
Re: turbo change
yup a 92 ln130 efi 2lte
- crazyclark31
Re: turbo change
KIWI_TERRANO wrote:depends what model surf 2lt you have is it efi and newer than 90?
The ct20b is also on the ikz te as well. It is by far the best of the toyota turbos.
They run smoother boost and don't tend to get as hot. And 2mm in wheel size is a bit in turbo speak
As for using petrol trubo,it quite a common practice. For a 2.4 d motor you'd want to look at a turbo off a 1.6-1.8ltr petrol. Even a td04 might be ok.
Fyi i run a tdo5h(subaru) in my safari,full boost was at 1800rpm(15psi) and held it all the way to 5200.
Re: turbo change
are they straight bolt on??
or a bit of fab work needed?
- KIWI_TERRANO
Re: turbo change
crazyclark31 wrote:KIWI_TERRANO wrote:depends what model surf 2lt you have is it efi and newer than 90?
Never heard of a 1kz with ct20b??? even my mate at dsl never heard of this from factory 1kz came with a ct12b,
all the ct20, ct26 should bolt straight on, mate has a ct26 or a ct20 manifold on a 5l 3ltr pretty sure he didnt change anything
Re: turbo change
samewan wrote:http://toyotasurf.asn.au/techsite/intercoolingpajero.htm
looks simple as
tho it requires a body lift.
Re: turbo change
yes that is true but thats not hard ether
