Driveline breathers
Posted: Tue Nov 29, 2011 10:03 am
by 3VILC
I read on another forum that the Hilux gearbox (YN67) breathes via the shifter, is this correct? I cant see a breather on the box anywhere unless im not looking hard enough. I assume that the box and transfer share the same oil supply and breathe thru the same place. So an extended breather project is just the diffs?
Clive
Re: Driveline breathers
Posted: Tue Nov 29, 2011 10:19 am
by vinceparts
if you take the shifter out , 4 12mm bolts, youll see a small 12mm o/d cap by about 16mm high , grab some pliers and pop it off and a small spring will come out too, just wack some hose and a hose clamp on and bring it up to the highest point oyu can
Posted: Tue Nov 29, 2011 9:32 pm
by 3VILC
Ok so whipped the front one out to try and unclog it (thinking this was probably not helping the leaking axle seals), was like it when I got it, think the seller mustve done the dodgy and given everything a good wipe over so i couldnt see the oil trails (theres a tui ad here "we just changed the diff oils, yeah right") .. annnyway where was I, yup pulled the breather, and theres grey oily sludge under there, yay a good sign of water.. not entirely sure I want to pull the bungs out for a nosey now :| hopefully drop the oil, clean it all out, do the seals, and no major damage.. at least dreams are free :cry:
