landcruiser vx 80,2'' lift
bobby r
Stropper
Post by bobby r »
was quoted by two different shops in Auckland around $3000.- for fitting old man emu gear,shocks,coil springs,steering damper etc.incl.fitting,has anyone here done anything like that to their vx 80 more cost effective/better? i thought the price i was given is a little step,cheers.
Danjr
Re: landcruiser vx 80,2'' lift
Post by Danjr »
bobby r wrote:was quoted by two different shops in Auckland around $3000.- for fitting old man emu gear,shocks,coil springs,steering damper etc.incl.fitting,has anyone here done anything like that to their vx 80 more cost effective/better? i thought the price i was given is a little step,cheers.
$800 odd for Shocks
$650 odd for Springs
$200 for a Steering Damper
Not sure if that includes a castor correction kit but that's another few hundred so you're already up to a couple of grand. Plus a wheel alignment. Then there's the labour of fitting and it starts to add up.
A mate and I put a 5 inch lift in mine and that was about two and a half grand and that was at mates rates on the parts and doing the work ourselves.
If you want to do it cheaper, shop around on parts and do it yourself if you can. Otherwise it seems reasonable.
Dan
mayday
Post by mayday »
You can try Dean on 09 4265016, It wont be OME gear but will be good service
bobby r
Stropper
Post by bobby r »
thanks guys,appreciate your response.
