hi there
how many engine mounts and where are they all located on an 85 surf?
engine mounts 85 surf
- BeamedSurf
- Bush Crasher
Toyota Hilux Surf SSR LN60 Beam Axle
Build in progress
Build in progress
Re: engine mounts 85 surf
there should be 2 and they will be located around where the front wheel is on the inside of the chassis.
Sam
Sam
- BeamedSurf
- Bush Crasher
is there a gearbox mount other then on the cross member?
Build in progress
Build in progress
- tomsoffroad
- Flopsie
- BeamedSurf
- Bush Crasher
