Fitting Extractors
Posted: Mon Dec 12, 2011 1:55 pm
by dtchch
I've bought a set of Coby extractors (sold the other car you see
I'm going to do a thread on how to mount them, so will take photos as I go.
My cat converter has previously been removed, so the plan at this stage is:
Cut standard exhaust back if/where required.
Source two short lengths of steel tube (which will fit over the exhaust pipes) and weld a flange to connect them.
Weld the length of tube over the end of the extractor pipe/beginning of existing pipe.
This should allow me to remove the exhaust manifold if required, without having to chop the pipe or remove the full exhaust.
Any tips will be appreciated, I figure this should be a fairly simple way installing the new extractors.
Re: Fitting Extractors
Posted: Mon Dec 12, 2011 5:22 pm
by zephyrheaven
Make sure you drill your O2 sensor hole BEFORE you fit them (customer tried to be smart & fit his own, ruined an O2 sensor trying to screw it in & 'modifying it' to fit ahem....
That & dont break any studs / fit a new manifold gasket
Have fun!
Posted: Mon Dec 12, 2011 8:49 pm
by QUADRACER
add a flexy bend, will last longer offroad
Posted: Tue Dec 13, 2011 8:08 am
by dtchch
Where can I find one in Christchurch? Got a link so I know what to look for?
Posted: Tue Dec 13, 2011 8:23 am
by vinceparts
get one off trademe, exhaust shops want mooooooooooob=n beams for them
http://www.trademe.co.nz/motors/car-par ... 658868.htm
Posted: Tue Dec 13, 2011 9:07 am
by kernels
Start spraying the nuts on the exhaust studs with CRC now, spray them again every few hours, practically impossible to get them off if you don't!
Posted: Tue Dec 13, 2011 9:50 am
by dtchch
Thanks mate, I think standard exhaust is 2" though??
Posted: Tue Dec 13, 2011 10:06 am
by vinceparts
dtchch wrote:Thanks mate, I think standard exhaust is 2" though??
was just a picture and a price comparison to others, if you got a 2.25 inch or sumthn would slip over and make life so much easier to line up and weld etc
Posted: Tue Dec 13, 2011 10:26 am
by dtchch
vinceparts wrote:dtchch wrote:Thanks mate, I think standard exhaust is 2" though??
http://www.trademe.co.nz/motors/car-par ... 046821.htmFor reference, this seller seems to do most sizes and are cheap as.
Will order the 2.25" once confirmed I need 2"
Posted: Tue Dec 13, 2011 11:20 am
by dtchch
Craig from Mudbits recommends putting a 250mm resonator within 1m of the manifold - has anyone here done this?
I figure I'll go to Magoo Mufflers this weekend and get a flange as well as the resonator
Posted: Wed Dec 14, 2011 8:25 am
by lincooln
yea I got a resonator just after the dump on the extractors. then heads into a M&H muffler. It is 2.25" exhaust and is actually quite quiet. Intake noise from the snorkel is louder.
Posted: Thu Dec 15, 2011 10:31 am
by dtchch
Shiny new extractors just arrived
I'm going to try them without a muffler up front and see how it goes, if it's too raspy and loud I'll put one in.
This will be a job for the weekend so I'll update and post some pics then
