Hi
I've been wanting to try get my A/C working on my cruiser, but don't know much about them.
It's been unplugged ever since I've owned it.
I found two plugs that were unplugged, but only found where to plug one back in. It's the plug (single pin) that runs to the clutch on the pump by the looks of it. However theres another plug that runs to something behind the compressor.
I've checked the fuse in the box to the right of pedals, but that's fine.
Any idea what to check?
Help with A/C please
Re: Help with A/C please
I had this problem with my A/C. I resorted to unbolting the pump and I found a little switch that it connected to.
Some systems wont run if there is not enough pressure i.e little or no refrigerant. Best bet is to get it checked over by an Aircond man....
