Hey folks, new to the forum thing so hopefully I get this in the right place etc.
I'm trying to identify the gearbox in my Hilux. Not a straight forward as checking the chassis tag i'm afraid.
The truck has been re-bodied and re-powered, with a 350 chev. I was told the box was from a Dyna, with the hilux transfer case adapted on, (possibly using a Dellow adaptor kit). HOWEVER: The Dyna box is meant to have the same front bolt pattern as the R series Hilux box. Mine has anything but!
The box has 4 bolts holding it to the bellhousing. The bolts go through externally cast lugs on the box, so you can see them clearly with the gearbox still in the truck.
A couple of clues for those who might be in the know. The box is 5 speed, conventional shift pattern. It has right side shift mechanisms (mod-ed for the Hilux) and two switches on the selector shafts - it seems to me one is for exhaust brakes, the other reversing lights. It has a VERY low first gear. All of this points to Dyna I know, but the external mounting has got me confused. Oh - it has a mechanical speedo drive on the drivers side, and a large flat bolt on inspection/access cover on the left (passengers) side.
I can try and post pics, but the techo side of it might be a challenge for me, and the box is still in the truck. If anyone has any pearls of wisdom, I'd be glad for the advice.
Can anyone ID this gearbox?
- Bush Crasher
- ClassicCruiserSpares
- Sausage Shack
Re: Can anyone ID this gearbox?
The dyna gearbox was always linkage driven because there a truck so no gear lever but they can be converted to stick shift but the gear pattern moves from right to left instead of left to right.
Sound like a cruiser box they have the 4 external lugs and are a common gearbox to bolt to chevs.
- Bush Crasher
Thanks for that - I'll see what I can dredge up on the net. I may not have been clear in the post, the box is a linkage shift type. It has two levers exiting the box on the right side and then going into a homade shifter contraption to convert to floor shift. Does that still sound like a cruiser? I had an FJ45 - I didn't think it had linkages, but that was a few beers ago......
- Sausage Shack
Argh ok, yea not cruiser then if it has linkages for the shifter, then it does sound like dyna gearbox they did have the external mounting lugs.
- Bush Crasher
Thanks again. Marks Adaptors and other places on the net reckon the Dyna box has the same mounting bolt pattern as the R series Hilux, rather than the 4 external bolts. Blessed if i know!
I want to ditch the 'dyna' box and install a Hilux box for better on road driveability. If the bolt pattern I have is not R series hilux, (I'm sure it's not) I'll also need a bellhousing to mate the 350 to the Hilux box. The idea is if i can ID what box is in there now, I may be able to source a better on-road box that will fit my existing bellhousing.
Unless anyone out there has got a 350 to Hilux bellhousing they want to part with cheap???
- Sausage Shack
This is early dyna box
But the later ones are similar to hilux the way the mount to the bellhousing.
- Bush Crasher
You are the man! That's the box I have. Really appreciate your help.
