Toyota 5L valve adjustment
Petemcc
Post by Petemcc »
Hi guys,
I am wanting to adjust the valves in my hilux. Its a ln106 but it has a 5l out of a hiace in it.
After some research I have determined i will need a tool for removing the valve shims (to push the lifter down while you pull the shim out) I understand that some people make do with screwdrivers etc but I would rather use the correct tool so that I don't risk damaging anything.
So my question is does anyone know where I could get one of these tools from? I am down in Qtwn but have a mate coming down from chch in the next few days and could get him to pick one up for me.
Also where do you get new shims from? Just toyota or are they a common thing?. And do you just buy the ones you need or can I buy a mix of different sizes so I can do the job all in one go?
My other option is to just send it to someone to get it done which I assume would cost about the same as buying the tool and a micrometer... however if I got all the bits now it would be free next time!
Pete
kbushnz
Re: Toyota 5L valve adjustment
Post by kbushnz »
Before purchasing tools, have you checked them?
They may already be ok.....
The shims are expensive and I would only change what you need to....
And from memory its only one shim......They have different thicknesses....
You might be able to mix and match what you already have until you end up with just a few to replace....
Also they are done when engine is Cold.....
My 1KZTE and 2LT and 3L manuals all have a chart which tells you what shim to use depending on what gap you have....
Petemcc
Post by Petemcc »
Yea I have checked them following the manual and all exhaust valves a well below the specified clearance.
The tool I am after is like the one in this video... This guy has a box of shims, that's what I want haha. It would be interesting to know how many engines have the same size shims.
How expensive are you talking for shims? Have you bought some before?
Looking at the video the tool doesn't look like it would be too expensive
Pete
kbushnz
Post by kbushnz »
The shims are real common between the Toyota Diesels.
Here are some numbers
13753‑54010 厚さ=2.50, T01
13753‑54060 厚さ=2.60, T06
13753‑54110 厚さ=2.70, T11
13753‑54160 厚さ=2.80, T16
13753‑54210 厚さ=2.90, T21
13753‑54260 厚さ=3.00, T26
13753‑54310 厚さ=3.10, T31
13753‑54360 厚さ=3.20, T36
13753‑54410 厚さ=3.30, T41
13753‑54420 厚さ=2.55, T42
13753‑54430 厚さ=2.65, T43
13753‑54440 厚さ=2.75, T44
13753‑54450 厚さ=2.85, T45
13753‑54460 厚さ=2.95, T46
13753‑54470 厚さ=3.05, T47
13753‑54480 厚さ=3.15, T48
13753‑54490 厚さ=3.25, T49
Can't remember the price...
Have fun....
