new bushings time
Posted: Sun Mar 11, 2012 9:03 pm
by ArvinSlayer
so i am starting to hear clacking sounds, checked the ol haynes manual, they reckon that its bush changing time, as do i and several other experts in the field, so my question is, do i get some nolathanes on or go for the original nissan part, or are there some better option?? i dont mind spending the money to get a good set of bushes, but i want a GOOD set, seeing that factory has lasted me 190kms, just opens me up to a whole world of options and i would like th suggestions of my trusted forum members
Arvin Slayer
Re: new bushings time
Posted: Sun Mar 11, 2012 9:13 pm
by crazyclark31
go factory bushes. Only way to go
Posted: Sun Mar 11, 2012 10:33 pm
by curly12
ArvinSlayer wrote: nolathanes
Nope, too stiff and don't let the front end flex, go factory.....
Posted: Mon Mar 12, 2012 5:21 pm
by slide
go factory, nolathane wear out far to quickly
Posted: Mon Mar 12, 2012 8:31 pm
by muskie
factory bushes are 40 each plus, i have had this conversation earlier today, nissan are out of stock presently, you will need to ring around the dealers. genuine parts are the ONLY way to go for longterm use..
what alot of people dont do when they lift the truck is release the bolts so the bushes find there new position....
Posted: Mon Mar 12, 2012 8:56 pm
by coxsy
oh good ,nissan out of stock ,need new fronts for drop boxes
Posted: Wed Mar 14, 2012 10:35 am
by ArvinSlayer
yea i havent had much luck either, but my mate reckons i should try australian sources as they have a bigger pathy market there, will sort that and put up any info i find
Posted: Wed Mar 14, 2012 12:25 pm
by suzolla
Hi,
Front or rear.
If it rear I think the terrano and safari are the same, the Nissan people can correct me if I am wrong.
I possibly have some rear ones that I bought for a project but have not used yet, if they are what you want could let you have some but would need to replace them. Need to check the dimensions.
Also I think each end of the links has a different sized internal tube.
Nissan people may be able ot expand on the difference.
Tim
Posted: Wed Mar 14, 2012 1:15 pm
by oldblue
If it's the Front Suspension arm bush's, the 70series Prado are the same size.
Posted: Wed Mar 14, 2012 3:46 pm
by coxsy
visted nissan front arm bushes in stock $94 each
superior here i come
Posted: Wed Mar 14, 2012 5:30 pm
by andrew007
try 4wdbits.co.nz,rubber with holes for more flex
Posted: Wed Mar 14, 2012 6:27 pm
by coxsy
duh forgot about them
Posted: Wed Mar 14, 2012 9:22 pm
by coxsy
done cheaper than nissan and not as far away as in queensland
Posted: Wed Mar 14, 2012 10:55 pm
by jeremy
...or don kyatt normally have them in stock.
Posted: Thu Mar 15, 2012 3:23 pm
by coxsy
oh do they,to late 4wdbits got the order after a lot of sodding around on web sites, ect
Posted: Thu Mar 15, 2012 4:12 pm
by nismo26
I got some from the Mount Shop they were only $40 each.
Posted: Thu Mar 15, 2012 5:47 pm
by coxsy
out of stock they lose
Posted: Thu Mar 15, 2012 6:06 pm
by mudlva
contact bus and truck they carry an assortment of rubber nissan bushes
i got the front diff radius arm bushes for around $20.00 each they didnt have any radius arm to chassis in stock tho
Posted: Thu Mar 15, 2012 8:17 pm
by jeremy
yup, what I said.
bus and truck = don kyatt = terrain tamer
