new bushings time
For all Nissan related topics
ArvinSlayer
new bushings time
Post by ArvinSlayer »
so i am starting to hear clacking sounds, checked the ol haynes manual, they reckon that its bush changing time, as do i and several other experts in the field, so my question is, do i get some nolathanes on or go for the original nissan part, or are there some better option?? i dont mind spending the money to get a good set of bushes, but i want a GOOD set, seeing that factory has lasted me 190kms, just opens me up to a whole world of options and i would like th suggestions of my trusted forum members
Arvin Slayer
crazyclark31
Re: new bushings time
Post by crazyclark31 »
go factory bushes. Only way to go
curly12
Post by curly12 »
ArvinSlayer wrote: nolathanes
Nope, too stiff and don't let the front end flex, go factory.....
slide
Post by slide »
go factory, nolathane wear out far to quickly
muskie
Post by muskie »
factory bushes are 40 each plus, i have had this conversation earlier today, nissan are out of stock presently, you will need to ring around the dealers. genuine parts are the ONLY way to go for longterm use..
what alot of people dont do when they lift the truck is release the bolts so the bushes find there new position....
oh good ,nissan out of stock ,need new fronts for drop boxes
ArvinSlayer
yea i havent had much luck either, but my mate reckons i should try australian sources as they have a bigger pathy market there, will sort that and put up any info i find
suzolla
Post by suzolla »
Hi,
Front or rear.
If it rear I think the terrano and safari are the same, the Nissan people can correct me if I am wrong.
I possibly have some rear ones that I bought for a project but have not used yet, if they are what you want could let you have some but would need to replace them. Need to check the dimensions.
Also I think each end of the links has a different sized internal tube.
Nissan people may be able ot expand on the difference.
Tim
oldblue
Post by oldblue »
If it's the Front Suspension arm bush's, the 70series Prado are the same size.
visted nissan front arm bushes in stock $94 each :shock: superior here i come :D
andrew007
Post by andrew007 »
try 4wdbits.co.nz,rubber with holes for more flex :mrgreen:
duh forgot about them :oops:
done cheaper than nissan and not as far away as in queensland
jeremy
Post by jeremy »
...or don kyatt normally have them in stock.
oh do they,to late 4wdbits got the order after a lot of sodding around on web sites, ect
nismo26
Post by nismo26 »
I got some from the Mount Shop they were only $40 each.
out of stock they lose :mrgreen:
mudlva
Post by mudlva »
contact bus and truck they carry an assortment of rubber nissan bushes
i got the front diff radius arm bushes for around $20.00 each they didnt have any radius arm to chassis in stock tho
jeremy
Post by jeremy »
yup, what I said.
bus and truck = don kyatt = terrain tamer 8)
