Trans Auto doesn't like OD in the cold
Posted: Fri Mar 23, 2012 9:43 am
by fullthrottle
Butters wrote:There was an issue a while ago where on a cold morning the truck would hold in gear on the open road. I thought it might have something to do with a 5 minutes of uphill driving i do from the second i leave my property so i’ve since taken it for a warmup around the block before tackling the hills – that did the trick but could have been pointing out a trans fault.
This is interesting and something mine does only when its cold. (It doesn't like going into Over Drive.) I was told by the local garage that the trans in the terranos does this until the temperature comes up. Some sort of safety mechanisim. Mine is a 1991 Terrano.
Anyone else know about this?
Re: Trans Auto doesn't like OD in the cold
Posted: Fri Mar 23, 2012 10:02 am
by Jay
Hey fullthrottle,
Yup, this is a safety feature to allow the engine to warm up quicker (higher rpm's). If I remember correctly, there is a thread on here somewhere that give's instructions to over ride this buy cutting and looping a wire that goes to the converter lock-up in the tran's loom. The safari auto is the same i believe.
My D21 was the same, but i never bothered...
Jay
Posted: Fri Mar 23, 2012 11:34 am
by pruggerdore
yup correct, if the proplem gets worse ie takes longer and longer to go into lockup look at the trans temp sensor in the radiator.
Posted: Fri Mar 23, 2012 3:22 pm
by taz01
my saffy takes about 8/10ks to go into lockup from cold no warmup after that from standstill to top gear is changing at around 2000rpm lockup at 80ks kicks in still not right i think id like to get a few more rpm before changing .... i still have an issue with setting the tps sensor havnt been able to find of get correct setting ....
Posted: Fri Mar 23, 2012 5:24 pm
by Butters
Mine was keeping me out of top gear the entire way to Mosgiel from Dunedin each morning (about 15 minutes of open road driving). Quite aggressive shifting too, very jerky.
I should add that mine was driving like it was stuck in a lower gear. I know all about the 'hold' switch too haha
Posted: Sat Mar 24, 2012 10:44 pm
by The Stranger
Never really paid it another thought as the owners manual says this is normal when cold.
