The opinions and viewpoints expressed by users of Offroad-Express Forums are wholly their own and not necessarily those of Offroad-Express. https://www.offroadexpress.kiwi:443/Forums/
just wanting to know what the stud pattern is i know its 5 stud but what is the spacing
noob question i know
also looking at getting some nascar "D" centre centres and some outters to make my own offset wheels
plus will a 32-33" tyres fit under one of these with a 4" lift?
Re: 2001 jeep grand cherokee LTD
Posted: Mon Apr 23, 2012 12:56 am
by TJ
2001 Grand Cherokees would be 5 on 5" (or 5 on 127mm for metrics, but Jeeps aren't metric - really).
Now where the difference is in the trims. Limiteds and Overlands had 17 x 7.5" rims from factory. Laredos had 16 x 7" rims.
One thing to note on a 2001, from 1999 model production through May 10, 2002 used Teves calipers, black color with open-sided bracket. These are prone to rotor warpage as its not a good design. Later years had Akebono calipers, which is what you want. Some of the original Teves were replaced to later Akebono calipers through Jeep initiative/repairs. Just keep an eye on it.
My wife drives a 2003 Grand Limited. So I know a little bit about them from the last 4 years. Ours is a 4.7l V8, not the diesel.
Posted: Mon Apr 23, 2012 12:59 am
by TJ
Forgot, the offset is 50.8mm from factory.
If you do decide to go down the WJ/WG route, keep this website in your reference material: http://www.wjjeeps.com
Posted: Mon Apr 23, 2012 1:12 am
by TJ
Just did some reading on another site. You will struggle to fit 33" tyres on it unless you go 6" lift. The problem is the way wheelwells are shaped. Factory tyres on a Limited are P235/65R17, which means 29.5" - with a 4" lift 31/32" might be doable.
Our WG is factory standard, and it will remain that way. Far too much money and time needed to mod two Jeeps.
Posted: Mon Apr 23, 2012 5:41 am
by xj
Im saving my ponies for a '05+ 5.7 Hemi GC to use as a tow wagon... hhmmmmmmm
Posted: Mon Apr 23, 2012 4:50 pm
by luckyme
safaripete wrote: plus will a 32-33" tyres fit under one of these with a 4" lift?
33s only fit with 4" lift if you cut the sh!t out of it AND proper offset rims. but you can put 2" spacers(200 bucks+couple of hours) on the coils and you got the 6" lift.
at this stage i only got the 2" BBs on 2002 limited with 31s on factory 17" rims and because of the crap offset tires rub a little on the shocks and the frame.
with any lift/bigger tires you wanna change front driveshaft to the u-joint style: http://www.ironrockoffroad.com/Merchant ... y_Code=WDT the slip yoke version isn’t the strongest - just shattered mine on the weekend
worth considering long arm kit as well, 4"+ shorties ride like a pig they say
go with quadra-trac version with the V8 if you don't mind buying up Gull
might wanna think about an engine rebuild(unless it's already done), check diffs, axles for any noise.
I think ex USA might be the lift kit. Nobody will do a RHD conversion for that price. Need more photos but 270k kms are not too much for the V8 if maintained well with quality parts. It will need a thorough check though. What has been done to the rest of drive line.
Why is it being sold. Also those 16 rims are from a Laredo not Limited.
Posted: Mon Apr 23, 2012 9:01 pm
by xj
id just about do ya my ZJ for the same price with bar, winch, front locker, 32's, 8 inch rims, 4 inch lift, custom rear bar with tyre carrier, 4:10 diffs, uni'd front driveshaft, uni'd front axles, selectable 2wd (XJ case) etc etc etc..... sorry for the spam thradjack... but im just sayn.....
Posted: Tue Apr 24, 2012 4:13 pm
by badnuz
BUT would you swap his V8 Calais????
Posted: Tue Apr 24, 2012 5:22 pm
by xj
My Calais aint going anywhere!
Posted: Tue Apr 24, 2012 5:53 pm
by safaripete
no my v8 calais
Posted: Tue Apr 24, 2012 7:04 pm
by xj
I'll show you mine if you show me yours!
Posted: Tue Apr 24, 2012 9:58 pm
by safaripete
Posted: Tue Apr 24, 2012 10:06 pm
by TJ
safaripete wrote:
Great donor engine for a V8 conversion
Posted: Tue Apr 24, 2012 10:56 pm
by xj
Posted: Tue Apr 24, 2012 11:11 pm
by badnuz
show off
Posted: Wed Apr 25, 2012 11:17 pm
by safaripete
i have made the decision to get the jeep so with any luck next friday i will head up to taupo n get it
now on the look out for some 16" steel wheels
and some 285 75 16s mud tyres or 265s
Posted: Wed Apr 25, 2012 11:29 pm
by TJ
safaripete wrote:i have made the decision to get the jeep so with any luck next friday i will head up to taupo n get it
Great, I am on the look out for new wheels and tyres as well. My 265/75R16 BFGs are down to 40% tread, time to replace.
Posted: Wed Apr 25, 2012 11:39 pm
by safaripete
have been looking on some american sites at the rims
they work out around 100 nzd plus shipping which isnt too bad if you cant get them locally
at a guess shipping will be a killer but i will wait till i have the jeep up my driveway before investigating any further
Posted: Thu May 03, 2012 6:10 pm
by safaripete
it is now up my driveway
pics soon
Posted: Thu May 03, 2012 6:50 pm
by luckyme
safaripete wrote:it is now up my driveway
pics soon
welcome to the Dub Club mate
Posted: Thu May 03, 2012 7:22 pm
by safaripete
had its 1st venture off road tonite
(onto the front lawn)
Posted: Thu May 03, 2012 7:47 pm
by TJ
safaripete wrote::mrgreen:
Great. Fun starts now. Some of the sites I frequently use:
need to fix the blower motor first lol tis bloody cold in there without it
seems its a resistor going by searches on the net can other confirm this?
Posted: Thu May 03, 2012 10:58 pm
by TJ
Are you sure? What are the symptoms. Limiteds have dual zone HVAC. If one side is blow cold air and the other side blowing hot or no air, chances are your blendoors are out of action. You can check what the codes are.
1) Turn on the vehicle. 2) Turn on the AC system to any setting. 3) Hold down the AC and the Recirculation buttons at the same time. 4) While still holding the AC and Recirculation button, turn the passenger side temperature control knob clockwise one click. 5) Release the AC and Re-Circulation buttons.
The code numbers will be displayed on the screen one at a time.
Report what the codes show up. If they are 22, 24, 54 or 56 then its the blendoors. Easy to fix.
Posted: Thu May 03, 2012 11:01 pm
by safaripete
the blower motor isnt going at all
but can get heat out of both sides and cold
have done the fualt code check yet mite go do that soon
Posted: Thu May 03, 2012 11:06 pm
by TJ
On ours, eventually both blendoors had failed and no air would come out of the vents. I also thought the blower was blown, but the codes showed it was the blendoors. I fixed them first and the motor failure codes went away.
When the doors fail, they fall in a position (due to gravity) that stops flow of air from the top almost completely.
