Commy gearbox problems
Posted: Tue Aug 07, 2012 10:33 am
by muddyplumber
Just been on godley trip n took the zuk,another problem happened on the way home.have a vn motor n auto box n it now doesn't seem to change into top gear....has got plenty of oil in trans...does anyone no what could be going on?is it time to biff it out?and do I have to find another vn box or will something like a vl box fit up to it.thanks Rich
Re: Commy gearbox problems
Posted: Thu Aug 16, 2012 6:34 pm
by muddyplumber
Pick Apart has just come to chch found a gear box 60bucks :mrgreen: ( just gotta get it out) vs $480+gst
Posted: Sat Aug 18, 2012 7:45 pm
by aroma
where are pick a part in chch
Posted: Sat Aug 18, 2012 7:50 pm
by muddyplumber
Halswell junction road,Hornby end,can't miss the massive yellow guy holding a spanner
Posted: Sat Aug 18, 2012 8:08 pm
by tomsoffroad
We've had 2 Vn autos do exactly the same thing in the Navara. Binned em :mrgreen: I think possibly the Navara needs a bigger cooler which is happening at the moment as we are installing a whole new cooling system on it 8)
Posted: Sun Aug 19, 2012 8:40 am
by muddyplumber
Hey Tom yea your right about the cooling system,may have to look at adding in a fan of some kind as when I got stuck on the godley trip I could hear the trans fluid boiling which probley didn't help the gearbox much :lol: got new box now just gotta fit in.
Rich
Posted: Sun Aug 19, 2012 12:05 pm
by pruggerdore
my vn trans in hilux gets hot wont change up. only happens when the trans cooler fan stops
Posted: Sun Aug 19, 2012 12:36 pm
by muddyplumber
Hey mate,Are you running a small separate fan on the trans cooler that just runs off a switch?
Posted: Sun Aug 19, 2012 3:32 pm
by pruggerdore
My setup, radiator on back with large fan setup on backside of radiator sucking thru radiator set on a thermal switch so dosnt run all the time. on front of radiator a smallsh fan runs full time pushing air thru radiator providing enough cooling for light running conditions. now on the air drawing side of the smaller fan I have my trans cooler so it gets a small amount of air flow over it all the time. works well.
Posted: Sun Aug 19, 2012 3:35 pm
by pruggerdore
fans either need there own thermal switch or run as soon as you turn ignition on. if you have to manually switch on sooner or later your going to forget. But its ok the exploding radiator usualy reminds people lol
