Hilux slipping in 1st gear
Posted: Mon Aug 13, 2012 1:22 pm
by AngusM
have a 2.8D ln106, recently had clutch done (less than 500km ago) but it feels like it slips a bit going up steep hills and on take off in first gear, wouldnt think it was clutch as all other gears are fine, even going up hills etc.
thought it could be transmission itself.
any ideas on what the problem is?
cheers,
Angus
Re: Hilux slipping in 1st gear
Posted: Mon Aug 13, 2012 1:34 pm
by Sadam_Husain
did you adjust the pushrod after you stuck the new clutch in?
Posted: Mon Aug 13, 2012 1:50 pm
by AngusM
It was done by a mechanic, no doubt I'll go back and ask if he did or not. Assumed he would have?
Posted: Mon Aug 13, 2012 2:08 pm
by Sadam_Husain
probably the first thing you want to check that theres a bit of freeplay in the pushrod
edit* if it was only put in 500km ago you probably want to go back to whoever put it in and let them know theres a problem
Posted: Mon Aug 13, 2012 8:43 pm
by AngusM
Cheers will do
