WTB, Toyota tie rod weld in taper insert
churchill
Post by churchill »
FJ80 style tie rod, need a weld in insert with the right taper in it. Anyone in NZ do one?
suzolla
Re: WTB, Toyota tie rod weld in taper insert
Post by suzolla »
I have a reamer to suit 80 series tie rod ends. Need a bit more details as to what you actually want, may be able to make what you want.
Tim
churchill
Post by churchill »
Hey Tim, I need an insert with the taper in it that I can weld into a flat plate and fit the tie rod through.
All it really to be is a bit of round bar with the taper in it. I can forward you some dimension if you like.
suzolla
Post by suzolla »
Easy as, send length and diameter, do you want it just in mild steel, or something a bit better.
Tim
