Hi
My 1KZTE has a heater just above the inlet manifold. It is piped to the block just below. It is heated by water from the water jacket.
Why did toyota do this? I though heating the air just before the inlet manifold would be a bad thing.
Can I just bypass the heater? Does it cause any issues?
Henry.
1KZTE inlet manifold heater Removal.
Re: 1KZTE inlet manifold heater Removal.
Hi Yah Henry
Some of our 1KZTE's were winter spec from Japan...I suppose it stops the butterfly's from freezing....
I had mine disconnected for years...Due intercooler install and remote throttle body...
I just looped the hose back on itself at the block.... Essentially by passing the throttle body.
Hi Calvin
Thanks for that. I will do the loop thing.
