yn60 surf fuel gauge flapping
Hi my fuel gauge flaps once the petrol goes down abit, to fix this would it be just a case of swaping another sender unit in? or could it be something dodgyer? if you turn key off it stops where the true level is.
Re: yn60 surf fuel gauge flapping
Normally the fuel gauge in the dash has a damping mechanism to stop that... I'd be more suspicious of the gauge than the sender.
Do you have a spare instrument cluster to try?
Used to
had a spares truck , Sold/binned everything when we moved south didnt think id get another surf for a while. its not a major il just get another to swap in.
Thanks Stu
Thanks Stu
Thanks Stu
