wtd mq safari gearbox transfer case NI
after a mq safari or patrol box to go behind a ld28 t in a s2a
Re: wtd mq safari gearbox transfer case NI
unless your putting mk/mq diffs in too it as the diffs are off centre....well will sorta work but not nice
WARNING:
got it in one chap ,
LR diffs are off center nugget the same,
mq diffs are next on the list.
i'm pulling the cab to do chassis rust anyway so ditching the landrover box makes sense at the same time
