For Sale : Suzuki Parts
UBZ
Post by UBZ »
having a a New Years clean out of surplus parts.
open to offers on the following Suzuki parts
2x SJ413 Front Diff Heads : 22 spline ,3.9 ratio.
1x SJ413 Rear Diff Head : 26 spine ,3.9 ratio
1x Set SJ413 Axles and Cv's
1x SJ413 Complete Rear Diff - Drum to Drum , 3.9 ratio
1x SJ413 front diff housing - bare - RESERVED
1x Barina (swift) power steering pump / bracket - will bolt directly to the G13a engine
1x Vitara In Tank electric Fuel Pump - RESERVED
1x SJ413 starter motor
1x SJ413 Softtop
1x SJ413 long side transfer case arm
would also consider trades for 16" Suzuki or Jeep rims .
Parts are in West Auckland .
suzookyman
Re: For Sale : Suzuki Parts
Post by suzookyman »
Whats the soft top exactly ?
UBZ
Post by UBZ »
suzookyman wrote:Whats the soft top exactly ?
A soft top cover to fit a soft top 410 / 413 / samurai or coliy . haven't had it out in while , but from memory just needs the rear flap zips fixed .
suzookyman
does it have the side brackets to hold it up? how much?
Al
Rotazuk
Post by Rotazuk »
Don't junk the 413 front housing . If its ok I will probably get it off you and hord it . Also the fuel pump :)
Chris
UBZ
Post by UBZ »
Rotazuk wrote:Don't junk the 413 front housing . If its ok I will probably get it off you and hord it . Also the fuel pump :)
No worries ill put them aside for you . I think I got The pump off you originally :lol: :lol:
suzookyman wrote:does it have the side brackets to hold it up? how much?
Al
I never had the brackets / hoops to go with it , but should be too hard to fab something up that would work.
No idea what it's worth , will dig it out this arvo and have a good look at it .
make me an offer . would love to see it put to use .
suzookyman
Al
Let me know if its in good nick, I have a set of 16 inch zook rims ( same as on your LJ ) with half worn SAT's on them......... maybe we could work something out ( after 413 bits 8) )
Al
