Okay, so mine has karked it which is apparently a common issue. I have two questions:
1: Where can I get anther motor from which will not require re-mortgaging the house or...
2: Is it possible to retrofit a manual winder assembly? I actually quite like this option as electric windows and I are not mates. Are the doors the same for a manual winder setup? Any ideas?
Cheers, Eddie
Driver's Door window electric motor - 80 Series
- Eddie Auckland
- Driver/Navigator
Re: Driver's Door window electric motor - 80 Series
will have a look at home, pretty sure i still have one in my parts bus.
will get back to you.
- Eddie Auckland
- Driver/Navigator
wopass wrote:will have a look at home, pretty sure i still have one in my parts bus.
Thanks!
hachi_roku
you can buy brand new aftermarket power window regs out of aus for like $150 each, thats a complete motor and reg.
Pick a part has similar year, large Toyota cars which are very similar. ( except for the plug). you may also need to get one from the opposite side of the vehicle. When you remove the motor from the pick a part car cut the wiring harness so you can make an adapter.
Tony.
- Eddie Auckland
- Driver/Navigator
Mudde1 wrote:Pick a part has similar year, large Toyota cars which are very similar. ( except for the plug). you may also need to get one from the opposite side of the vehicle. When you remove the motor from the pick a part car cut the wiring harness so you can make an adapter.
Thanks for that. Will try them tomorrow. Think the Camry ones are a match, similar year should work. I can easily solder the wiring (two whole wires) into the old plug!
im pretty sure if you need the drivers side one you can use the passanger side form 185 surf, 90,95 prado
and same in reverse for passanger
some Corona rears are the same, same plug too
