2.4 diesel (2lt) leaking diesel from the pump and turbo is a gonner and the steering box is leaking, I have not done any research on the steering, but might be able get a seal kit for that too.
I may be able to re-seal the fuel injector pump (will need some advice tho
My turbo is stuffed. the turbines are cracked and have some play in the shaft and replacing the turbines means re-balancing so need a second hand one with good turbines.
if anyone has a fuel injector pump, turbo and/or power steering box (Its solid axle not IFS) that they are happy to part with that would be great
Thanks
